Discuss Scantronic ion-16 alarm system shut down, can't get running again. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Initially disconnected 4wires on keypad with power switched off at fused spur reconnected wires back in order system failed to reboot blank keypad all fuses checked hav had an electrician look at it but 2 no avail possibly keypad not sure.any help or advice much appreciated thx
If the keypad lights up, but has no text A&B data terminals are usually incorrect, otherwise system corrupted, and requires full nvm reset, look in manual for resetting system
you will need to open the main panel up and take a look at the glass fuses and probably one will need replacing. usually there are 3 fuses (for different purposes) but that naturally varies from panel to panel.
ive never fit an ion but from what i know they are fairly recent so it may not have fuses at all....
if it does, if you have a continuity tester of some sort you can check using that, if not, you can usually see a gap in the wire or something to give it away.
make sure you get the right fuse size too just incase there is a problem\fault
If keypad is not lit then as above or damaged keypad
Reply to Scantronic ion-16 alarm system shut down, can't get running again. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
