Mithrass
Hi Folks,
After some experimenting I have concluded that the Scantronic control panel has a limited range of tag numbers that it will accept. I have dozens of tags, all of which respond normally to an RFID reader, and some of which were specified as compatible with Scantronic panels. But only a few of them are recognised by the panel. The others do not even cause a beep and cannot be registered to a user.
The ones that work all have numbers beginning with 0000. the others begin with 000x where x is any number not zero.
Does anyone have any information about the compatible range of tag numbers? Or am I just doing something wrong?
The system is a Scantronic 9752 with a 9651 panel.
Thanks for any advice.
