scedule of inspections | on ElectriciansForums
Discuss scedule of inspections in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
blenki
Hi , regarding the shedule of inspections on an EIC a lot of houses do not have diagrams,instructions or circuit charts in them , do you guys put an X in the box and if so how do you rectify the situation
If its a PIR and it passes apart from that, then you could supply a circuit schedule.
You will need to findout what the circuits are doing anyway so it wont take long.
I have a template saved on my desktop specifically for this purpose, and for CU changes etc.
If you have just done a new circuit etc that doesnt warrant you touching any others then it can be justed noted as a 4 in the departures.
Hey mate.
As long as everything in the c.u - RCD's, MCB's etc are labelled for use in a domestic premesis then that's enough for me.
You can't really expect to see circuit charts and layout diagrams.
A little thing I do is photocopy the circuit details/test results page of the form and leave it by the board, folded up inside the visor.
Hope this helps.
Cheers jason , ive got part p assessment coming up and im doing a CU change , just making sure i get my paperwork sorted !
Ta lenny , i was thinking i was gonna have to go out and buy a laminator !
No need for buying one of those, however, i put them in those clear pvc wallets.
If you are doing a CU change then yes, you should complete one.
No need to worry about diagrams etc, but make sure the CU has ALL the labels on it: RCD test, next inspection by, and 2 colour warning label.
And just to add if 100A cutout fuse make sure you have 25mm tails comming from meter output to CU.
Regards
Kung.
Reply to scedule of inspections in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes, probably overthinkig, thanks.
