Scenario for use | on ElectriciansForums
Discuss Scenario for use in the UK Electrical Forum area at ElectriciansForums.net
M
marco86
You are testing a clients house and the kitchen and bathroom lights are wiring in 1.5mm twin and earth.
The bathroom (x 6) and kitchen (x8) have down lights. The cpc have been chopped away due to the installer not being a spark and noticed there was no termination point at the light? So between each downright the cpc has just been chopped.
What would you code it as?
What about installing a new smoke alarm circuit into a rewireable fuse board, cables pass through the ceiling and clipped direct to joints in attic.
Would you say that the db requires changing so that cables are rcd protected ??
Which is cheapest, replacing an old CU with a modern one or adding a small CU with RCD and leaving the existing CU alone?
New consumer unit as needs RCD as at some point it will be in wall/partition
Or
"Preferably supplied from local, regularly used lighting circuit. (there should be a means of isolating the supply to the alarm without switching off the lighting)"
Also
"be linked so that operation of one will initiate all"
Or
Also
Doesn't necessarily need a complete new consumer unit though. Other methods are available, such as Spoon's suggestion. Daz
The consumer unit may be fairly cheap, but the labour costs of installing and testing it won't be. And any faults and issues which come to light will also need sorting. Could work out as a very expensive new smoke alarm! Daz
i did give TWO suggestions, think the other suggestion is from the Building Regs onsite guide
Every thing has COSTS and DIFFERENT ways of doing things, the two i suggested
were down to my thinking the Cost of the Smaller CU with a RCD was dearer than the suggestion out of the building regs, the Full CU i figure maybe a bit dearer but would help with the RE-wireable Fuses and being up to date with RCD, the CUs are cheaper at the moment, a House with a Reasonably NEW CU is better to be sold than one with a OLD Re-wireable Fuse one as the looks of it would scare people off, but im sure coffee might fix the problem as the smell dose help to sell houses i hear.
Reply to Scenario for use in the UK Electrical Forum area at ElectriciansForums.net
There is no homework, and I'll never see these photo again.
