J
JONOXNAM
Scenario: Installed a complete new lighting circuit for a customer & at the same time added to an existing lightning circuit. All the work is to be recorded on a single EIC with sched of tests and inspections etc.
When filling in the Schedule of inspections do you ONLY include the items you installed? (e.g: if the modified lighting circuit has SELV originally in place and you DO NOT install any SELV does the form require you to 'tick' or N/A the SELV box?
I am not able to find anything in the regs to make it clear such as - the sched of inspections relates only to the works defined in the description and extent of the installation - it may be there but I cant see it.. I know there is something like that for PIR's and now the EICR....
Many thanks.
Many thanks.
