Schedule Of Inspections question | on ElectriciansForums
Discuss Schedule Of Inspections question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
Benjjy02
Im sure this is a
regular question on here but here we go again
If the “Routing of cables in prescribed zones” requires ether a tick or a cross on the Schedule of inspections, for i.e. a CU replacement, but the
routing of the cables is a mystery to the installer, What should be
done?
This is for my NICinspection so I appreciate any help
Ben
@ malcolmasanford- Im only a rookie at this, but my understanding is with an EIC only a tick or cross is acceptable.
@ topquak- I wouldnt like to disagree with greater men than me, but iv alway been led to believe once you replace the PD then you are responsible for that
circuit. Do you know where it says “only responsible for work done”?
Thanks for your responses
You are issueing an EIC for the work you have carried out nothing else.
So in the 'extent of installation covered by this certificate' box you would write 'upgrading of CU only' When it then comes to the 'routing of cables in prescribed zones' box on the inspection schedule you would write N/A as you havn't installed and cables only replaced the CU.
OK. say you are replacing a CU. the only way to find out if cables are roted in prescribed zones is :
1. lift floor boards to ensure cables are below 50mm deep, drilled through joists, not notched. 2. use a metal/cable detector on the walls to ensure the cables are vertical and/or horizontal from accessories (no diagonal runs).
suppose that cables run under the bathroom floor which is tiled. are you going to rip up tiles and flooring to determine cable location?
that is where the n/a or n/v comes in. what you can't check, you have to enter as malcolm said. no use ticking a box if you can't verify.
I'll throw this one in then, I always put a tick in it. I have stated in the EIC that the certificate is for the replacement of the CU only, hence the schedule is applicable to the work I am doing on the CU. Therefore I have routed all the cables that I have dealt with in a prescribed zone. This also applies when I move accessories and the like so long as I have described where I have done so, ie 'kitchen area only'. Any thoughts on that? I'm always open to corrections and other ideas....
I would only tick the box, if I had actually installed cables.
Fully agree, once you have completed the 'Details Of The Installation' box then you have limited your liability and anything on the Schedule of Inspections can only relate to your work description.
Reply to Schedule Of Inspections question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
Protection from what? What kind of problem with the inverter is going to be helped by having an RCD on the circuit?
davesparks
