Hi Guys was looking for help when filling in inspection schedules say for example a CU change And an additional circuit install. when testing the final circuits say your circuit is routed in prescribed zones, but you have noticed old circuits are in notches in joists with no protection is this a pass but in your notes insert there that you have found this upon inspection or does it just get marked down as a x fail.Same say you instal another lighting circuit sleeve the two way ect but upon testing and inspectng other lighting circuits switch wire and the like are not identified is this again a pass or fail.
Cheers
Cheers
