schletter mounting kit part deux | on ElectriciansForums
Discuss schletter mounting kit part deux in the Green Lounge (Access Only) area at ElectriciansForums.net
Leeds
*previously in this saga... We're in the process of changing from Schuco to Schletter mounting kit because our supplier convinced us it was just as good and would save us a fair amount of money*
So we're now doing our first schletter installs, and I don't know if it's just a case of 'fearing change' or not, but I'm finding all sorts of problems with the kit, which seems to be a lot less forgiving of none standard roofs than the schuco kit.
Problems I've found so far are
1 - The module clips need to have the rails at almost exactly 90deg to the edge of the panels due to the way they clip into the rails, whereas Shuco could be at virtually any angle. We're currently doing an old house where the rafters seem to be running at around 75 deg angle to the panels, and it looks like I might have to end up starting again and running it all in cruciform just to get the rails straight so I can get the clips in position. This wouldn't previously have been a problem because we always had spare rails and cruciform kit in stock, but now we have nothing other than the exact kit we ordered for this job, so will have to delay for a couple of days to get the cruciform kit delivered, and doing it cruciform will make it more expensive than if we'd used schuco.
2 - the ECO rails are a lot more flexible than the cheapest schuco rails we used, so I think we'll realistically have to be using the more expensive solo rails most of the time, so there's not going to be much in the way of savings going on there either - actually they cost more than the BP130 rails from schuco.
3 - the rails are in exact 4 or 6m lengths, so if you're doing 6 x 1m wide panels you can't just use a single length of rail as you can with the schuco rails that are actually 6.18m long.
4 - The brackets that have vertical adjustment for the tile height as well as for the rail height to get the rails level are actually more expensive than the schuco brackets that do the same thing.
5 - when using hanger bolts, the entire height adjustment for the rails is done via the actual height on the bolt, and there's less scope for side to side adjustment to allow for the hanger bolts not being entirely in line with each other.
6 - The end clips for the panels for some reason are double width clips, so will be a lot more visibly stuck out from the end of the panels than with the more discreet schuco clips.
mark me down in the unimpressed column so far.
It is true that if you don't care at all about being able to level the rails up properly, or ensuring the bracket is the correct distance from the tiles, or that you're using a much more flexible rail etc that you can probably save money with these system, but if you do care about any of that, then it looks like schuco is actually the better and cheaper option.
Looked at many many different makes of rail, but still come back to K2, it really is the best, so good infact alot have tried to copy their designs
is anyone using schletter that fancies talking us out of swapping back to Schuco?
as that's the way I'm leaning right now.
Wagner & Co - Montagesystem TRIC A - YouTube
very easy m8, even do hangers that adjust vertically if you have an uneven roof, only one bad thing is they are quite high so panels look high off the roof, seen a few installs round my end where panels look like they sit of the roof about 2 inches
there is a company by me that make a rail system called mipower, looks bloody lovely as it puts a capping around the array, been past a few and looks fansastic.
@grandfortune - that's SEN Sol-50 system, we've used it a few times, and your right it looks the dogs b***** however it is also probably the most expensive system available on the market! ( www.sen.eu ) as the rails have to be the exact right place you end up having to cross-rail them.
we ended up scrabbling around and finding enough schuco sanyo clips to actually do that job, then matching some of their bolts with the square nuts that happen to be a part of the schletter clips that also slotted into the rails as an alternative method for the clips.
That's ridiculous to have to do that just because the rafters aren't at 90 deg to the rest of the roof - this was fairly extreme as roofs go, but it's times like that that the adaptability of the schuco kit has always saved us.
the eco rails are also schockingly bad in flexibility terms, although I guess their better in environmental terms because of the lower volume of metal used.
Reply to schletter mounting kit part deux in the Green Lounge (Access Only) area at ElectriciansForums.net
