schletter roof hook slate | on ElectriciansForums
Discuss schletter roof hook slate in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
fareham
Has anyone used these shletter slate hooks? We usually use solar flash but these look pretty good!
Yeah they are solid but would recommend a bit of foam on the underside because even with your clearance you can still get some rattle from them. Also, led under and above for water tightness, why not use limpets though?
Reply to schletter roof hook slate in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I'm looking for advise on the type of mounting system suitable for these types of tiles. These are sort found on new build houses. They are...
Apparently so, I’ve copied and pasted below. Octopus Energy, named by the Renewable Energy Association (REA) as “the company that has done the...
