F
Festerfly
Ive been tasked with providing the electrical supply for a new Home Economics room in a local private school.
I have the plans for the installation which comprises of
8x Freestanding Electric Cookers (32A Max each)
12 x 2g Switched Sockets (light load only)
Now this isnt normally an issue, however! The main incoming board is around 20 meters away. It is currently full to capacity and is also an Old Federal Electric Board so didn't relish the idea of finding a used breaker to fit to this ageing discontinued board. Replacing the main board isnt an option. My plan was to take a feed from the tails into an isolator and then run the supply to a smaller 3PH board located in the Home Econ store cupboard and then run the feeds out from there.
My concern is that if i give each cooker its own supply from the local board they would end up on different phases and with some of the cookers standing back to back, if there was ever to be a fault then there is the potential for a shock across two phases which i am keen to avoid tbh. I was planning on running 4mm radials to each cooker and a 2.5mm ring to the sockets. the rest of the wiring (lighting/extractor etc) is straightforward. I would probably go with RCBO's on all circuits to be on the safe side.
Any thoughts on this as i want it to be as safe as possible given the location of the install.
