scottish building regs | on ElectriciansForums
Discuss scottish building regs in the UK Electrical Forum area at ElectriciansForums.net
dave30
hello looking at doing a replacement consumer unit job they have old fuzes now and want rcds mcbs ... its for a friend if i dont get payed for the work do i need to infirm building control about it
and im in scotland so its scottish regs
if i do is it before or after the work
and can you tell me ware you find out info
thanks for all your help
The last page of this guide should help you http://www.sbsc.uk.net/docs/Getting-it-Right-in-Scotland.pdf
Changing consumer unit requires a warrant if the property is a flat or house with one or more storeys over 4.5m only or where the work adversely affects a party wall in a house with no storey over 4.5m.
It's also worth calling the local authority - they're usually quite helpful - mine advised that no warrant was required for rewiring my home but obviously reminded me that it must comply the current Building Regulations.
the responsibilty of informing building control also rests with the homeowner. As long as you carry out the required testing and issue the paperwork to customer then you have done your part. also as we have no part pee there is no requirment to join a scheme, you only have to prove "competence".
As rsmck says, warrant required only if a flat/maisonnette etc. Whether you are paid for doing the job or not is immaterial. If notification is required - if you are a member of SELECT or NICEIC then you you can submit EIC to meet warrant requirements; if not you will have to pay the local Council to arrange certification (I say "you" but in reality your customer/friend).
Tbh, I know that many sparks/their customers don't notify rewires/ cu replacements when they should - the real problem may arise if customer goes to sell the property and the rewire/cu replacement is noticed, and the purchaser's solicitor asks for the BW!
Regards
Reply to scottish building regs in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
