scottish spark advice | on ElectriciansForums
Discuss scottish spark advice in the UK Electrical Forum area at ElectriciansForums.net
Glasgow
I'm a fully qualified 17th edition electrician. I am just wondering if i am able to sign off test certification for private housing. I have checked and it says as long as i am deemed competant but that seems a loose interpretation.
Some local authority's ask for a membership of a competence scheme.
Not entirely sure why this is however I've not had any test sheets returned by any councils building control.
I've passed the 2391, and a HNC also so not sure if the 2391 shows a level of understanding.
Yes, you can sign off your own work on an EIC or MEIWC. If it's for a builder they will probably want you to be a member of a scheme e.g. SELECT, as will the Council if the work is subject to Building Warrant.
Regards.
Reply to scottish spark advice in the UK Electrical Forum area at ElectriciansForums.net
very true indeed, absolutely agree, however a lot of businesses do like their sparks to be in a scheme, so Part P aside joining the NICEIC for...
thanks for the replies. Appreciate it.
