Scrap cable stripper...... | on ElectriciansForums
Discuss Scrap cable stripper...... in the UK Electrical Forum area at ElectriciansForums.net
Heres my homemade one, can do upto 120mm singles or armour cores (not tried anything bigger)
Also does T&E on the other side but never really use it as it's hardly worth it.
[ElectriciansForums.net] Scrap cable stripper......
That's a beast rocboni!
Do you steal...ahem, acquire, lots of cable? LOL!
I have a modest few drums of old colour cable and had a look on fleabay where the going rate is a couple of quid and more for the old 2.5 t&e...hardly seems worth stripping it if I can sell a drum for ÂŁÂŁÂŁÂŁs
I do seem to acquire a lot of cable, usually because it is overordered, (not buy me) Or strip out quite a bit, got a load of 120mm armoured to strip ATM, an this only cost me about ÂŁ20 for the motor off eBay. I had everything else or made it, I've got an inverter on it to control the speed. Had thousands through it to date.
anyone recommend a scrap cable stripper?
It's called an apprentice in a room with all the scrap cable piled up and a heater left on to soften the insulation. He gets a cut same as everybody else. I've seen them stripping cable and left out it's a terrible thing to do.
* Kevlar woven glove on non knife holding hand cut away from the body.
Cheers
Reply to Scrap cable stripper...... in the UK Electrical Forum area at ElectriciansForums.net
Got these about 35 years ago as an apprentice, have tried every new fangled version cable stripper since and still rate them the best. Got a...
I have used it a couple of times, I do like it but it depends on the circumstances, they say it can be used for outdoor/wet areas with CT1 in the...
