scrap cable stripping tool | on ElectriciansForums
Discuss scrap cable stripping tool in the UK Electrical Forum area at ElectriciansForums.net
I
iamelectric
bought a tool off ebay for stripping singles didnt expect it to work as it was only a bit of metal with holes drilled in it , it was only ÂŁ12 so a thought i would give it a try and to my amazement it works i stipped about 40 metres of 6mm in about 2 minutes , i used to just take it to the scrappys without stripping it and get pennys.
Just drill a few small holes into a block of wood around 1" from the top, then insert a woodscrew from the top down into the hole you've just drilled. Poke cable through hole (around 6" i.e. Enough to get hold of). Tighten screw against sheath until it pierces, then pull remainder through. You're welcome :17:
Reply to scrap cable stripping tool in the UK Electrical Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
