Sealing a consumer unit entry points?? | Page 4 | on ElectriciansForums
Discuss Sealing a consumer unit entry points?? in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
leebut
Bury
Hello Guys
I'm going to put my Tin hat on and close the curtains so the Regs police can't arrest me for asking this question again, I can only find old threads pre 18th edition so please advise me if I'm missing something
I've just been watching a guy on Youtube doing a board change who's said that to comply with the 18th edition of the Wiring Regulations you must seal ALL entry holes into a consumer unit regardless of them coming through the bottom, top, sides or rear entry with a suitable intumescent mastic to stop the spread of fire into the fabrication of the building!!!
I personally am NOT aware that anything changed in the 18th Edition to say all entry points have to be fire sealed I've been looking online tonight and can only find write ups from "Wiring Matters"
Stating
Sealing of wiring entries
It is important for the installer to seal all openings into the enclosure or cabinet for cables, conduits, trunking or ducting that remain after the installation of cables - see Figure 6. The intent of the sealing is to ensure that, as far as is reasonably practicable, any fire is contained within the enclosure or cabinet and the escape of flames to the surroundings of the cabinet or enclosure or into conduits trunking or ducting is minimised, as intended by Regulation 421.1.201.
Good workmanship and proper materials must be used, and account must be taken of the manufacturer’s relevant instructions, if any.
Regulation 421.1.201 Does not mention sealing any apertures in a consumer unit with, grommets, glands or sealant and does not mention that the Metal clad board cannot be fitted to a timber backboard. So why is the IET saying we are to be sealing the holes , personally I've been installing all my boards with cables entering from behind and mounting my boards on the existing wooden backboards using a length of stick on trunking as a framework around the consumer unit.
Am I wrong???
To be fair you can only act on the information you have and from the little bit of the video I watched it sounds like he got duff information on his course.
Totally agree. He comes across as one that listens to whatever is said to them then spits it back out without thought. It's a common trait in our industry these days. So much misinformation about. I really think the IET needs to be more proactive with publicly clarifying information related to regulation changes. This could only benefit the industry.
I’m glad my videos bring awareness to such grey areas in the industry. This is exactly why I make videos on a public format so they get shared around and discussed. Appreciate any feedback good or bad. Even though some of you guys are damn right nasty without even knowing me.
Hi Chris
I am a fan of you videoblogs
I think you do a good job of explaining what you are doing and why you are doing it
Keep up the vids mate
Maintaining the fire integrity of a metal consumer unit surely is common sense no?
My jtl guy that did our 18th is also an NICEIC inspector he was very passionate about fire safety to the point we should also be fitting intumescent pads in the back of plastic boxes in stud partitions. A little added protection never hurts anyone and for the sake of ÂŁ2.89 I will continue to do so.
Did this genius of an inspector tell you where in the Regulations that additional fire protection must be put in place. The Regulations state they should be constructed from non-combustible materials. It should be remembered a consumer unit enclosure is not a fire barrier but just a non-combustible enclosure. To manufacture a consumer unit which acts as a fire barrier would not be practical or cost effective.
As has been mentioned before the CU's are now manufactured from non-combustible material therefore there's nothing to combust therefore fire-sealing is not required.
What about all the items within the CU that can combust?
I can see merit in sealing any large gaps or holes in the top or sides of the board ,
1 to maintain the correct IP rating
2 to improve any lost fire integrity
But I personally think all this fuss about avoiding plastic boxes , plastic clips , plastic wall plugs and plastic glands is ridiculous.
Hi Chris
Where will this end it’s not a building regulation or more a wiring regulation to fit intumescent pads in drywall boxes, it’s just someone’s take on the regs not actually the regs.
If it was a regulation for fire integrity the edges of the CU would have intumescent seals also the hinged lid would too, most manufacturers have top hinges to stop the spread of fire but the odd manufacturer has bottom hinge with a magnetic catch fire could spread from the front but like I say it’s NOT a regulation to seal it.
Makes no sense to seal everything it makes the job harder for the next man to come along when he’s adding the extension etc
Lee
Why bother, the new CU being metal, means it won't catch fire :)
Because I've have OCD's :D
I also worked on a building where a metal control board set on fire inside and the heat was intense enough for the wooden partition next to it to spontaneously com-busted, even though the flames did not escape the metal enclosure. I was quite astonished by this at the time and it stuck in my mind.
So in effect, you form a chimney in a plastic flammable material, (I'm assuming plastic as I've never seen sticky back metal trunking), with an opening from the CU into the chimney? Bit like cladding a tower block??
I use the sticky trunking to stand my metal clad consumer unit off the wall or wooden back board so my cables all enter the board through the rear entry holes so that flames from this non existent fire can’t escape the CU, I very rarely knock a knock out of either the sides or top
Status
Reply to Sealing a consumer unit entry points?? in the UK Electrical Forum area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
