Hi guys just a quick one. Have a 3 phase board in a small commercial unit fed from a single phase. Circular hole in bottom of cu is around 50mm in diameter and all that passes through is two 25mm tails and 16mm earth. What would be the best option to seal the hole without making a mess? Have found similar threads but these seems to centre around the hole being in the back (ie. into cavity) so options provided don't suit what we need. Our options are limited in regards to wholesalers (120 miles away), no delivery til Thursday, so would need to be something we could pick up in the likes of Jewsons or similar building merchants!
Thanks!
Thanks!
