Sealing off isolation valve Hi,
The isolation valve feeding my toilet cistern was leaking. After considerable effort, I was able to lift up the cistern to put an O-ring washer around the top of the inner circle referred to with an arrow in the attached image. Unfortunately, when I let the water through, there was a burst leak. Should I use a flat-ring washer instead? If so how can I get the right size?Should I put the ring at the top or push it down?
A friend suggested using also a jointing compound along with a PTFE tape; If a washer is enough, I won't buy these products
Thank you.
Sealing off isolation valve to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Thank you.
