StanFitz
Hi everyone,
I've been browsing the forum a while before posting this query. There's a lot of technical jargon between you guys so I hope you can tone it down a bit if you reply to my query.
I live in Cyprus and have bought some PV equipment from Italy and have an electrical guy putting it together for me. My system will be a stand-alone system because I am miles from the grid. He is not keen to do what I am about to ask but I need other opinions before dismissing the idea.
My kit consists of 15 X 175w panels, 10 x 12v (5x24v) batteries, charge controllers and an inverter.I have been offered another ten USED batteries to use with my system. My guy does'nt like the idea of using new and old batteries. My inverter has two inlets for DC current, maybe one for panels and batteries and another for a wind turbine. How would it be if the used batteries were a completely different battery bank (although charged with the same solar panels) and fed into the second DC inlet ?
The new batteries have two terminals each, pretty straight forward, but the used batteries have eight terminals - 4 poss. 4 neg. The Spec label on the used battery tells me :- CL1000(2v1000ah), Valve regulated rechargeable battery, Constant voltage charge, cycle use 2.40v-2.45v, standby use 2.25v-2.30v, Initial current less then 200A, Center Power Tech Co.Ltd. Can anyone tell me what I have and are they any good to me ?
Thanks in anticipation, Stan Fitz.
