second supply taken from cu incoming | on ElectriciansForums
Discuss second supply taken from cu incoming in the Australia area at ElectriciansForums.net
davidjones89
been to a property today to do a pir, on visual inspection of the garage( the garage had a dedicated metal clad cu suppling two circuits, these were lighting and power circuits) a second cable (swa) is taken from the incoming tails of the cu to an out-house with another cu supplying two circuits, again power and lighting. is this deemed acceptable ? plenty of room for conductors in garage cu incoming with supply cable being 6mm swa, same cable as second supply to out-house. supply to garage is taken from meter henley block, opinions welcome please,
Nothing wrong with the garage db, its less common these days, but not unheard of.
As Jason said, henley block should feed a sw/fuse, then feed the garage.
Might need to consider earthing arrangemets though.
Reply to second supply taken from cu incoming in the Australia area at ElectriciansForums.net
Your kWh figures are giving you consumption averaged over each hour period, but don't give an indication of total instantaneous current. To try...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
