Secondary loop pump + pipe stat | on ElectriciansForums
Discuss Secondary loop pump + pipe stat in the Central Heating Systems area at ElectriciansForums.net
sythai
Devon, United Kingdom
Hi Guys
Recently finished a new build house.
Commissioning engineer came in the other day (2nd visit whilst I wasn't there) and mentioned we need to put a pipe stat on the secondary loop pump.
We've only ever wired these as on/ off time controlled.
Apparently it's regs (heating engineer we work with hadn't come across this either before)
Any else aware of this ?
If so I assuming it's to prevent pump running if pipe is not up not temperature ?
Thanks Sy
Reply to Secondary loop pump + pipe stat in the Central Heating Systems area at ElectriciansForums.net
Actually, not too late as I've not had chance to revisit this issue since. I guess since we're getting into colder weather I ought to ...
Hello I have a Heatrae Sadia Electromax 9kW electric boiler that does hot water and central heating. Recently it broke and someone from Baxi...
completely agree with OP. Only thing I’d add, is how important it is to make sure the client knows exactly what you’r testing and noting it down...
    • Winner
Good evening Ed. Ed , yes i eventually found the reason for the fault & it drove me crazy. Ed, we found that there was a problem with the Main...
6K
