Securing cables behind coving | on ElectriciansForums
Discuss Securing cables behind coving in the Australia area at ElectriciansForums.net
Steve D
Hi All,
Is it feasible to run and secure cables in the void behind ceiling coving ? (prior to coving being erected).
I've not seen it done before, but I can't really see too much of an issue as it would certainly be in a safe zone.
Cheers
Steve
Its in the safe zone as you stated.
As long as there are no mechanical joints i.e maintenance free joints only or no joints at all. Cant see a problem.
Useful when customer wont allow you to lift floor boards to install wall lights.
And then you become a decorator too!
Reply to Securing cables behind coving in the Australia area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
