Securing modules to rail | on ElectriciansForums
Discuss Securing modules to rail in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
G
GaryM
I did the C&G2399 last week (hmmmm), anyway, the demo modules we used were manufactured by Sharp and had two locators on the underside of the panel which sat against the lower rail then the modules were secured by the spacer fixings between each other and an end clamp at each end.
Is that the same for all manufacturers of modules?
We regularly put 6mm SS bolts and nuts in the holes in the frames to help with positioning and anti-slip
Reply to Securing modules to rail in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
