security light cable | on ElectriciansForums
Discuss security light cable in the Australia area at ElectriciansForums.net
I
ijbswfc
hi, which cable would you guys use when linking 2 pir lights together so that either will trigger the other at the same time, i will need 3 core and earth as i need to link the switched lives together.it will be clipped direct to the outside of the house. SWA is no good and i can only get 3 core arctic cable. thanks
Can you not take the cables straight from the loft.Do you have to install a switch as an override or can you not install a switched fuse spur off the ring and take a 2 core twin and earth to a J/B and then feed the lights that way:D
As it stands there are allready 2 lights at the back and what is wanted is that the 2 new lights are added to the same switch downstairs ,i.e the one switch controls all 4 lights. just a spurr taken from the other outside light cable was what i wanted to do
How are the 2 lights fed already.Are they surface mounted or fed from the loft?:confused:Are they at high level near the guttering or a bit further down the building
they are surface mounted with the pirs low down feeding the lights that are up near the guttering, its a bit of a ball ache to be honest.And the 2 new ones will be a fair distance from the other 2
ive got a problem with access mac , i see what you are saying but the 2 new ones are going to be , 1 on the front of the house fairly high up and the other one down the side of the house over the porch, i would have a real problem wiring it internally.
[ElectriciansForums.net] security light cable
Have a look at this mate.It may help.Don't know how much you want to spend.Wireless control system.Website QVS Electrical Supplies | Electrical Wholesaler
Reply to security light cable in the Australia area at ElectriciansForums.net
Thanks for that, issue now sorted.
Hello - Did you get your problem sorted?
