Security Light Problem. | on ElectriciansForums
Discuss Security Light Problem. in the UK Electrical Forum area at ElectriciansForums.net
Gillingham, Dorset
Ran a security light off a fluresent light in kitchen.
Used 4 port supply push in wire connecter.
Earth and neutral wires connected inline to existing terminal blocks.
When I turn "OFF" bathroom fluresent light after use, the security light turns on.
What's causing this please?
Thanks!!
Do you have a two probe voltage test device (eg a multimeter).?
show us pics of the connections you have made at the new light and the kitchen light.
Yes I do have a two probe multimeter.
[ElectriciansForums.net] Security Light Problem.
Did you mean to say supply came from kitchen and turning off bathroom causes security light to come on?
Supply cable I assume comes from "bathroom too kitchen" as its closest to Consumer Unit.
Yes at night turning off bathroom switch causes Security Light to come on for the set period.
I'd be checking the terminals at the bathroom light switch anyhow, doubt that's the problem though
Is this a 3-plate arrangement with supplies at the lights and twins dropped to switches
On a different tack - might the security light be seeing light emanating from the bathroom?
It's presumably supposed to respond to IR from a person, and/or movement, but if it was detecting 'dusk' when the bathroom light goes off, might that switch it on?
Masking the detector should show one way or the other ?
Reply to Security Light Problem. in the UK Electrical Forum area at ElectriciansForums.net
There should be. Keep them all straight, insert two and then the third - don't twist them all together. If that doesn't work for some reason, use...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
