brucelee
Hi guys just want to check a few things out
my bruv wants a security light fitting on the rear of the house normally i would just come from a fused spur in a bedrrom but he has a large consevatory full length of the house so impossible
my only alternative is a attached garage, half of which as been coverted into a kitchen
the other half left as it was and used as a utility room where there is a existing double socket and i will install a 5 amp sw/f/spur from there i am thinking of running 1.0mm in trunking up to the roof space then over the new half of the kitchen in the rafters and out from the soffit of the extension into 20mm black conduit to a masterseal ip56 switch then continuing upto a adaptable waterproof box and then 1.0mm black flex to the flood which will be fitted with a angle bracket on the corner
Is this acceptable
should i use heat resistant flex or rubber sheathed ??
or is it ok to just use flex from the switch to the light as it seems a lot of expense just for a flood
i post a pic so you can see where its going cheers for any help
I am also soon going to change existing ccu and fuseboard for my assesment with elecsa but my bruv wants the light fitting before next saturday for a party thanks
Is this acceptable
