security lighting | on ElectriciansForums
Discuss security lighting in the Australia area at ElectriciansForums.net
dannyv
Can anyone recommend a make of security floodlight which are reliable and dont play up as the cheap one's ive been using are poor the pir's dont work properly. And do you just take a permanent live to your fittings or do you take a switch live perm and neutral? can anyone help cheers
Timeguard are OK. i take just L/N/E to the fitting, from a FCU., you can manually override by flicking the FCU switch on/off/on.
+1 for Timeguard. I have a Timeguard PIR at my front door, controlling 4 x 50watt GU10s in IP44 downlights. It has adjustments for lux levels (how dark it is before it works) and for the length of time it stays on once, activated. It detects down to the bottom of our drive and is activated by visiting humans, cats, dogs, cars, foxes and occasionally hedehogs (we are one house away from a field). I would say it switches about a dozen times a night and it must be at least six years since I fitted it. I doubt that you would get such reliability from a "Made in PRC" one.
Regards
Jon
Reply to security lighting in the Australia area at ElectriciansForums.net
Hello - Did you get your problem sorted?
