Seeing Through the Gloom | on ElectriciansForums
Discuss Seeing Through the Gloom in the Green Lounge (Access Only) area at ElectriciansForums.net
Just received an email containing the pdf report from John Dashwood - Head of Renewables at PWC.
Obviously confidentiality isn't a great issue for these guys as I can see the other recipients - usual suspects on the list such as Solar City, Leeds Solar, Solar Kingdom.....
A spammer's paradise :cry_smile:
Reply to Seeing Through the Gloom in the Green Lounge (Access Only) area at ElectriciansForums.net
Hi, just wondering if I have a cable passing through "100mm insulation at 2 points", do I use the correction factor of 100mm at 0.78 or 200 at 0.63
The sensitivity of the microwave sensor can usually be adjusted, most residents like the feature as it puts the lights on before they open the...
