Seeking electrical help for first time homeowner | on ElectriciansForums
Discuss Seeking electrical help for first time homeowner in the DIY Electrical Advice area at ElectriciansForums.net
Bht1725
Sacramento, CA
I am a first time homeowner trying to give my house a few updates on the mostly original 1984 aesthetic. One of the first things I started was replacing old yellow toggle switches with bright white rocker switches. I came across a double switch in the kitchen/dining room area that had some DIY work done in the past and now seems to be causing problems.
In the photo the left side switch controls kitchen over head lights and the right powers a fan above the dining room controlled by remote. It seems there is also power spliced from this that leads to the garage to control a wall light.
The problem I'm having is that when I connect the bottom (further from ground screw) wire to the right switch there is no function for the left switch and the garage light. When I disconnect it, the kitchen and garage work fine.
Also when I pulled the switches out of the box a twist and a loose wire came out as well. Not sure if that lose wire was some sort of bridge between the two.
I'm not sure what the issue here is or what to do. Any advice is appreciated as I am trying to solve myself but if neccessary I am willing to call a pro.
TL;DR
DIY from previous owner has left me confused on a simple switch replacement.where one switch doesn't work when the other is connected. Please look at the picture and let me know if you see something out of the ordinary, dangerous, or if I need a professional.
  • [ElectriciansForums.net] Seeking electrical help for first time homeowner
I think I found a solution late last night. I clipped the short wire coming from the left switch and used half to connect the right switch, left switch, and the loose black wire with a wire cap. Seemed to fix what problem I had.
Reply to Seeking electrical help for first time homeowner in the DIY Electrical Advice area at ElectriciansForums.net
Hello freddo (and everyone else who commented!), Thanks for your comment. Using that info, I now have this on the main: and this on the...
Thanks guys, I'm going for the safe option and take your advice in getting a qualified electrician to look at it. We've inherited these issues so...
