Selecting a 3 or 4 pole main switch | on ElectriciansForums
Discuss Selecting a 3 or 4 pole main switch in the UK Electrical Forum area at ElectriciansForums.net
TJC1
United Kingdom
Evening all
Pricing up a consumer unit change in a large industrial unit
When it comes to selecting a 3Pole main switch for a 24 way distribution board, are there any factors that will change the decision between a 125A 3pole or 4pole main switch?
Evening all
Yes is there a requirement to switch the N?
If a TT installation then provision must be provided to isolate all live conductors so a 4 pole switch would be required.
For TN installations where the Neutral is considered reasonably connected to earth by a low impedance,then 3 pole isolation is all that is required.
A removable link for the neutral for testing purposes is still required
It is easier for IR testing on a TN system to have a four pole main switch.
I have, rightly or wrongly always fitted a 3 pole switch, but most of my work is industrial and TN, you probably only have to worry about it on farms and other remote installations.
As long as the neutral doesn’t break first before the line conductors when being switched
As above it's a potential mode of failure. Triple pole is better where the neutral doesn't need to be switched IMO.
I alway fit 4 pole to make testing easier
Is ease of testing really the most important consideration here? How much easier is it than dropping out the neutral test link and is that saving worth the potential risks?
If a four pole switch is used then it has the potential for the neutral contact to fail or not close in the correct sequence leading to a dangerous situation and significant damage to equipment. Far better to leave the neutral solid/unswitched wherever possible.
Reply to Selecting a 3 or 4 pole main switch in the UK Electrical Forum area at ElectriciansForums.net
I've seen a few posts here which tend to suggest that wiring in a motorhome (or caravan) wouldn't be subject to normal inspection rules, but even...
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
