K
knxhome
It is planned to install a central 24V SELV supply in a domestic residence, e.g. to power LEDs.
According to my reading, BS 7671:2008 chapter 414.4.1 (ii) requirements for protective separation between a SELV and 230V circuits offer the following options
a) double insulation -or-
b) reinforced insulation -or-
c) basic insulation and protective screening
for the highest voltage present.
Which value should be assumed here for "highest voltage present"? 230V or 230V plus potential voltage spikes?
Or to put it more simple: which cables (in the 1.5 to 10mm2 range) would be suitable for the SELV circuit according to option a), i.e. where SELV and 230V cables may run next to each other without further spatial separation?
Thanks in advance.
Thanks in advance.
