SELV Testing | on ElectriciansForums
Discuss SELV Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
smokey73
Hi can anyone give me any advice on how to test a lighting radial with selv in them do i have to remove the transformer been told it could blow it if i carry out the normal test. Only thing is i cant get to it its under a wooden floor:confused:
HELP!!!
depends what test you are talking about, ins resistance im assuming, if so and you have no access then join the line/neutral together for circuit and test to earth.
You can either test at 250v ir test or as said link out l-n then no potential will flow so wont damage anything on a 500v ir test but you need to note this on cert as L&N+E easier than disconnecting the tranny.
Reply to SELV Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
Interesting. Sounds unusual since it seems it was very lightly loaded. Not much you can do I suppose other than buy a replacement unit. Unless...
