M
MrTrance
Hi, uncle has build an outside garage, got sub main there for new fuse board.
My question is;
He has a lampost in the back yard (lantern thing), the armoured cable is in the garage ready to be wired but he wants it to come on from a sensor mounted on the garage.
Is this correct, take the armoured to a metal clad switch, then a 3 core from the switch to the outside mounted sensor?
What would I have to do?
Cheers guys
Yes.....supply from CU to metalclad SFS, a 3 core cable upto the PIR & also the SWA to the lampost.
Make the connections in the back of the SFS, jobs a good un. You could also install another 1w switch as an failsafe to switch off and on manually should the PIR fail.
So all 3 cables going into the SFS? What do I do with the 3core then because theres only supply and a load? Both live and switch live in load side with the L+N from armoured, and the neutrals in choc?
Sensor question
Australia
MrTrance,
keniff,
