Biff61
Guys,
Hi, need some advice on sequential timers.
I need to set up 6 containers with 2 ton (24,000BTU) Inverter Split Air Conditioner units supplied through individual contactors, I am looking for a sequential timer that can allow me to space a starting sequence of 15 seconds between each unit. The ST shall only be operating the coils of the contactors the AC load shall not be through them
The units shall be run off generators and I need the loading of the set to be sequential to avoid the it shutting down.
I need something that is practically idiot proof as when I am gone from this place the quality of the guys maintaining them requires something simple and easy to repalce. So any advice on a good unit out there I can get that will cover this scenario.
Thank you.
Thank you.
