Hi,
I’ve got a timeguard pir sensor for switching 3 led floodlights in various all at once. I’ve replaced it like for like as the lux dial had snapped off.
Wired it up and is illuminating on movement for minimum time set and going off great, but when I turn lux to dusk the light still comes on as if it’s in walk mode.
So at minute it’s coming on in daytime.
I did wonder do I need to power off before setting to dusk it’s just on normal pir sensor lights you can turn lux to total darkness and it when it goes out it doesn’t illuminate again till darkness
Any help greatly appreciated
Cheers
Cheers
