Setting timer from star contactor change to delta contactor | on ElectriciansForums
Discuss Setting timer from star contactor change to delta contactor in the Electrician Talk | All Countries area at ElectriciansForums.net
W
weyland
Hello everyone. I would like to know how many second we need to set on timer to change the star contactor to delta contactor. Is it depend on motor rating. let's say i have 10hp motor. so how many second should i set on timer? Thanks
Will probably get shot down in flames for tis post , but hey ho !
I always set them by ear , once it sounds just about run up then that is where i set it .:behead:
Reply to Setting timer from star contactor change to delta contactor in the Electrician Talk | All Countries area at ElectriciansForums.net
Thank you for your response. I really appreciate it.
I got this all wired in and working thanks to the help from James, absolutely top man. Do have a small issue with current imbalance atm, L3...
