Setting up on my own | on ElectriciansForums
Discuss Setting up on my own in the Talk Electrician area at ElectriciansForums.net
R
Richard3009
I have been an JIB 16th edition approved electrician for 25 years, with good experience on domestic and industrial installations.
I wish to set up on my own, the inspection test and self certifying part is very confusing, do I need to get this qualification, any advice really welcomed, Im just trying to get an idea of where to start.
Thank you in advance
yes you require membership to :
niceic, napit, elecsa, eca to be able to sign off your own work (or pay building control direct - not really cost effective)
average price is about ÂŁ400 per year and as your qualified you will only need a onsite inspection of work :)
You are saying I need to sign up to all those, I thought you just needed to take part 1 of the inspection test course to certify your own work, what are most one man band electrical outfits doing to certify their work?
Am i not right in saying you do not have to be a member of any of these bodies its just most people prefer you are a member, domestically anyway:confused:
OK putting aside the organisation leeches, self certifying of installation what's the best route?, I assume 17th edition upgrade is the first port of call yes?
!7th edition update is a must. However, if you are up to 16th then they will allow you to do it within first 6 months ish of joining.
You do not need 2391 to self cert, although some schemes require it.
Self cert is the way to go. Notifying LABC yourself and paying them huge sums of money is pointless.
See what I mean about it being a grey area, there must be a set minumum requirement of qualification to self certify, I have seen certs issued with no registration number????
What is the bare essentials to self cert ones work; taking into account I'm already an approved JIB electrician, ie do a domestic electrical job hand over the required certificate of compliance and invoice the customer.
The minimum requirements are set by the government and one of them being 17th edition.
There is nothing whatsoever about having to be 2391 qualified as well. However, SOME of the schemes make this one of their requirements although i know the NIC DO NOT if you can prove competency through a more in depth assessment.
Read this, page 7: http://www.niceic.com/library/B5487--Guide-to-Enrolment.pdf
and this: ELECSA - Requirements & Costs
going with a group ie the niceic is a great option as this generates pleanty of work as the general public are advised to use nic companys and many estate agents who have testing done rq it to be done by an nic company, but you dont have to be in a group to self certify you can do it yourself take your part pand become part p registerd then all you have to do is send the local authority an email to issue a part p not sure what charges there are though but you need to ask how do plumbers certtify part p when carrying out minor electric work ie down lights in bathrooms and not pay the local authority a fortune.
They take a defined scope course which because most of them rarely use their newly aquired "skills" they forget about pretty soon after. Doesn't matter though because they already have a bit of paper which proves that they're competent(until something goes wrong)
its a disgrace lost count of the amount of times i have seen gu10 downlights in shower cubicles installed by plumbers every one should stick to their own trade .
So take part P whatever that is and become part P registered however you do that, :eek:
Fairly straight forward then???????
So before I can sell my trade do my job, I need to go back to school, you can't work in this country if you want to, no easy route then.
Reply to Setting up on my own in the Talk Electrician area at ElectriciansForums.net
So, I’m more aiming for the domestic setting myself and I don’t plan on EICR straight away. I am almost certainly not aiming for the industrial...
NICEIC Certification Scheme NICEIC Competant person scheme
This sounds very similar to me. My level 3 NVQ is in engineering maintenance and I also have a HNC in Operations Engineering. I’ve been working...
