setting up on my own | on ElectriciansForums
Discuss setting up on my own in the Business Related area at ElectriciansForums.net
hi guys just need a bit of advice please.
ive worked in industry over 20 years,for years been running electrical projects throughout the uk.the company i worked for have run into difficulties.
i have some quite good contacts for domestic and commercial work.
although i dont have 2391 i can test.
how can i do work for these clients if i need to be able to supply certification?
The key word as always is competence-are you competent to install and certificate your own work?
2391-10 will go a long way towards proving competence but it's not an exclusive thing, experience and 236/2360/2330 etc. along with 2382-10 or 20 all go into the 'competence pot'.
If you join up with nic etc they normally give you a period of time before you have to get the 2391 or 2392,you dont legally have to have 2391 to test & inspect but it proves competence on paper.
There is no such requirement for 2391-10 from NICEIC or ELECSA and in any event, 2391-10 does not prove competence, it will ASSIST in proving competence to test & inspect.
"3. Competence to inspect, test and certificate
Applicants holding a Certificate of Competence to ISO
17024 will have met this requirement. Other applicants
must obtain a certificate covering the requirements for
inspecting, testing and certificating electrical
installations. This must be held prior to registration or
obtained within 12 months of a successful on-site
assessment. Acceptable certificates include C&G2391,
C&G2400 or equivalent."
I don't think that's from NICEIC or ELECSA is it?
hi chaps
thanks for all your replies.
as i would be doing commercial and domestic will nic,elecsa and napit cover both of these works.
i take it once you pass the assesment you can then certify.
i was led to believe you had to be trading for a period of time before you could certify with nic??
Reply to setting up on my own in the Business Related area at ElectriciansForums.net
L
Electrician UK Electrician looking to move to Australia 2025 UK Electrician looking to move to Australia 2025 Hi Everyone Looking for some...
lewish121
L
C
Mechanical Services Estimator Does anyone have a need for an estimator to price commercial mechanical & public health works on an ad hoc basis...
Chico888
C
