M
MicraShed
The Immersun is reading "Water Hot" unless I have the thermostat on the Immersion element turned up to maximum.
Currently water coming out of the taps is at about 68 degrees - far too hot for comfort. But if I set the immersion element lower than this, the boiler thermostat calls for heat and the boiler kicks in.
I believe the problem is to do with the position of the thermostats - this diagram explains it a bit better.
I have a Primatic self priming water tank which also feeds the central heating system. The yellow diagonal line is the position of the Immersion element ( a 30-odd year old Redring 3kW) with the thermostat for this being right at the top of the hot water cylinder.
The orange square is the position of the boiler thermostat.
For now, I have turned the boiler thermostat down to about 45 degrees in the hope that this will prevent the boiler firing up to deliver heat to the cylinder - in winter this isnt an issue as the system is a gravity fed (non pumped) hot water set up so whilst the boiler is on for the heating water will be fed into the cylinder heating the hot water regardless of the cylinder stat status.
In summer the chances are that the Immersun will produce more than enough heat output for the cylinder so I can probably shut down the whole heating system. But its Spring & Autumn where I wouldnt normally have my heating on for the house but there may not be enough PV output to heat the tank - ideally I would rather set it up as a fit and forget, if the PV hasnt heated the water enough, the boiler kicks in automatically but at the moment I just cant get it right.
Three thoughts here - the old immersion element might be better replaced with a newer element (which also features a thermal cut out too for safety) possibly a shorter 2kW type - the thermostat on the immersion might then not cut out quite so soon. However I suspect its because the position of the thermostat is right at the top of the tank that it cuts out before the water lower down the tank is heated.
Two: Move the boiler thermostat further up the tank in the hope that the water is hotter further up the tank and that the boiler doesnt kick in unless needed - I need to draw off only one bath and one dishwasher worth of water a day, so really the tank is probably far bigger than we need.
Three: Fit a de-strat device (though I not sure I can to the primatic tank) to mix the hot and cold water at the top and bottom of the tank evenly.
Ultimatly I know Im going to have to fit some TMV's to the taps - probably the bath and the bathroom sinks. Looking at the tank take off types they dont seem suited to my plumbing set up (LP gravity hot water, and mains fed cold water at all taps).
So, any advice or thoughts?
