Can someone please tell me the maximum Zs for a 10A Type C Rcbo to BS En 61009-1?
Lol,
The MCB part of it from 41.3 gives 2.3 Ohms
The RCD part of it from 41.5 gives 1.67k Ohms, which translates into 200 Ohms
Looks like you're both right
However, .............. we always look at a R1 + R2 + the Suppliers Ze for a TN system which would satisfy the disconnection times in 41.1
correct lenny, but ignoring the rcd bit it would be 2.3
Lol,
where's 200 ohms come from?
heres my reasoning
when a circuit is protected by an rcd, the rcd will trip in the event of a fault between line conductor and protective conductor.the rcd will not operate in the event of a fault between live conductors, including line to neutral.
if the line to neutral loop impedance exceeds the values given in tables 41.3 & 41.4 the overcurrent device will not trip in the ggiven times that is 5s or instantaneously for circuit breakers. BS 7671 allows this situation in reg 435.1,providing overload protection is given by the overcurrent device and the abiatic equaution of 434.5.2is met
for simplicity designers will probably wish for the operation of the overcurrent device in the times of tables 41.3 & 41.4 in which case lengths need to be limited as follows----------
Here's a tip for future reference....
For type B breakers, max Zs = 46 ÷ In
For type C breakers, max Zs = 23 ÷ In
For type D breakers, max Zs = 11.5 ÷ In
Remembering this will save looking in the books all the time :coolgleamA:
Get the ADS max Zs side of things sorted (2.3 ohms), before you start relying on the 1667 ohms of the RCD element!!
Settle an arguement
Thread Tags
eddieboy,
Engineer54,
