Sharp NU 245kw Panel landscape orientation help | on ElectriciansForums
Discuss Sharp NU 245kw Panel landscape orientation help in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
shes-electric
Hello,
I wonder if any other installer can help. I am trying to install Sharp panels with the Schletter solo rails/ klickfit system and Eco V roof hooks. Some installers are telling me that they have installed and its below the 200mm threshold in height to avoid planning permission. I cant seem to make this work as my calculations always work out at about 210 to 220mm parallel from the roof.
have any other installers used the rails horizontally against the rafters to orientate landscape. I know that this can only be done when the rafters have the correct spacing.
PLEASE!!! any ideas? I don't want to have to get involved with planning authorities if I can help it.
Cheers
csal again why don,t you use all schelltter or all clickfit mounting system , or have they run out of stock again , or use slim modules eg solarworld at 31mm deep thinnest on the market
Reply to Sharp NU 245kw Panel landscape orientation help in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
Apparently so, I’ve copied and pasted below. Octopus Energy, named by the Renewable Energy Association (REA) as “the company that has done the...
