Sheathing | on ElectriciansForums
  • Thread starter Carol Hall
  • Start date
  • Replies 4
  • Views 3K
Discuss Sheathing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
Carol Hall
Hi
In current regs is it exceptable to plaster over househol wiring which has been rewired without using external sheathing?
Hi
When you say "external sheathing" do you mean the gray or can you see the coloured single wires?
If you can see the brown, blue and green/yellow then no you can't plaster over them, it needs to have the grey sheathing over it.
Hi
I'm assuming that you are referring to 'capping' and as has already been mentioned, it is not actually a requirement but was more for protection against the plasterers trowell and to protect the older types of cable sheaths against lime damage from the plaster.
Reply to Sheathing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for that link. I ended up buying this becasue I could buy it by the metre Pardon our interruption... -...
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
