A
amfletchers
Many years ago I had electric put from my house to the shed at the bottom of the garden.
I use a lot of power tools, however when using these the electric switches itself off. I guess it's because the powertools are very high voltage. When it goes off I just need to go inside the house to the fusebox to flick the electric back on. Every time I use powerful tools this happens.
Is there anyway to stop this happening? I know I may need an electrician to make some improvements or do some rewiring but I'd like to know the best solution and understand what the problem is before I do this.
Thanks,
Adam
it sounds as though the tools have a high start up current which is tripping the breaker, or is it that the RCD trips? these are separate issues, need a bit more info.
there is a solution but it requires testing first to see if it can be done without rewiring.. as you say , it's been in for a good while, so best have it checked out anyway.
if the MCB size has been chosen to suit the expected max. demand...what makes you think the cable hasn`t?.....
Sorry, thought it had been happening since it was fitted
Message to self:- Read posts thoroughly before replying:6:​
Shed Electric Keeps Switching Off
amfletchers,
Richard,
