Shed supply on PIR and external socket | on ElectriciansForums
Discuss Shed supply on PIR and external socket in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
O
oldtimer
Guys need some clarification on a supply to a shed the installation is TNCS with a 12 way Hagar CU No RCD installed June 2006.
There is a 32A 6mm supply from CU to a RCD 16A & 6A CBs mini board everything checks out but how does this appeear on the PIR ie 6mm circuit or do you add the power/light circuits highlighting them.
Also external weatherproof socket where does this stand with regards to RCD protection.
Thanks in advance
The supply to the shed is a distribution circuit and is treated as a separate circuit on the schedule for the DB feeding it.
The CU in the shed is treated as a separate DB and it's final circuits are listed on a separate schedule.
External sokets must be RCD protected...code 2
Reply to Shed supply on PIR and external socket in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thank you for another very helpful response. Just to assure you we are saying the same thing, I was referring to the 2.5 on 20A radial which I now...
Cheers guys, enjoyed reading all the responses. I'm an apprentice and it was a conversation that came up at work between two electricians...
2 3
