Shed supply | on ElectriciansForums
Discuss Shed supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sanke
Hi al
I have been looking at the brother in laws shed today & noticed that the swa comes into a switched fused spur
It only feeds one double socket, two fluorescent strips & two outside lights The swa comes off a 20a breaker RCD protected Is this okay to leave or should it be modified to two way cu in shed ?
I take it that the spur has a 5 or 3amp fuse in it and the lights come off the load and the socket is wired from the main side. If sothis is ok. Not brilliant but nothing wrong.
Hi hawk81
Yes it has a 3amp fuse As you say not best but it is protected with 3amp in spur as well as rcd Thanks for reply
:D
not much benefit if you mean 2 module(socket mcb and lighting mcb)
prob include an isolating switch if i was doing anything and configure lights,sockets so they don't have common rcd
Reply to Shed supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
