Shed wiring | on ElectriciansForums
Discuss Shed wiring in the UK Electrical Forum area at ElectriciansForums.net
J
jimzxcv
My sister has asked me to look into wiring of sheds for a new business venture.
All the ones I have looked at have a CU with separate lighting and socket circuits.
My idea to keep it simpler would be to put in a 4mm radial (as per reg 433.1 fig 15b) for sockets and run the lighting from an FCU on this circuit, thus eliminating the need for a CU in the shed & keeping it simple & cheap.
any problems with this?
Cheers
Jim
Cheers
Jim
The "shed end" is the easy bit. Its getting power out of the house to the shed that'll be far more variable and expensive.
Me thinks her business plan needs a revision.
Rewiring B+Q could be more than a one man venture
[ElectriciansForums.net] Shed wiring
Reply to Shed wiring in the UK Electrical Forum area at ElectriciansForums.net
Thank you for another very helpful response. Just to assure you we are saying the same thing, I was referring to the 2.5 on 20A radial which I now...
Do you know what percentage of scheme registered electricians are registered to sign off 3rd party work? Even better would be a poll of how many...
nicebutdim
N
