shop door chime | on ElectriciansForums
Discuss shop door chime in the UK Electrical Forum area at ElectriciansForums.net
N
Nuvo
hi all has anyone come across one of these its for the wifes dads garage it needs to be wired not wireless as had a few wireless and there all rubbish. basically i need some sort of pir sensor with a chime can anyonepoint me in the right direction cheers fellas
Standard shop door chime, you can buy battery operated ones, or use existing security alarm. Problem with using pir`s are it will keep activating when sensing movement instead of one single chime with door contact.
Reply to shop door chime in the UK Electrical Forum area at ElectriciansForums.net
Hello That sounds like a bit of a nightmare. Did you manage to get sorted in the end?
Thank you. We do have a window. Do you think my idea (even if is adds complexity) is workable? Nothing fundamentally wrong that I am missing?
