Short circuit and break up cable on fault finding rig | on ElectriciansForums
Discuss Short circuit and break up cable on fault finding rig in the Electrical Course Trainees Only area at ElectriciansForums.net
West Midlands
Can someone explain a short circuit And a break in a cable when fault finding please what is the meaning of them please. Was fault finding today on test rig
A short circuit is a direct contact ("fault of negligible impedance") between line and neutral or in three phase between line and line or line and neutral.
If you measured the resistance, with a low resistance ohmmeter, between the two conductors with a short circuit you would expect to see resistance levels much less than 1Ω.
If there is a conductor that is meant to be continuous and there is a break in the cable then the resistance from end to end of the cable, when measured with a low resistance ohmmeter would read full scale deflection (overlimit, >2000Ω, O/L, etc).
Normally a cable will show a low but measurable resistance.
Thanks mate
lee, just get some scrap cable/wire and a multimeter. have a play. see what happens when you cut cable or short it out.
I was tinkering at the weekend with an Insulation Resistance tester and a length of 4mm T+E. Pretty much had to cut through the lot and then squeeze it with pliers to get the IR tester to show a fault. Granted it was only a 1m length of 4mm, and a 100m length will probably show up a fault earlier, but still, I was expecting the insulation resistance to drop well before it did. Very interesting.
Reply to Short circuit and break up cable on fault finding rig in the Electrical Course Trainees Only area at ElectriciansForums.net
