Short Circuit Fault On Honeywell Flex 100 alarm | on ElectriciansForums
Discuss Short Circuit Fault On Honeywell Flex 100 alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Oxford
Hey,
We are putting in a Honeywell flex alarm. It's all wired in (following the manual). The problem is that all the sensors are coming up as having a short circuit and I can't work out why. I've wired it up with my friend (who is an electrician) and we really can't work out the problem. Can anyone help?
I'm based in Banbury and would be happy to pay someone to come and help.
Thank you,
James
Reply to Short Circuit Fault On Honeywell Flex 100 alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
Good point James. It would have been nice if the manual had mentioned which of the leads were being used for what though. It simply shows the LNE...
