Short on pos and neg | on ElectriciansForums
Discuss Short on pos and neg in the Lighting Forum area at ElectriciansForums.net
Redcar
Hi all,
I've just installed a new consumer unit in my garage. No issues with that but the lighting I have installed has a short across positive and negative.
I have fault finded by disconnecting all cables and find no short. Including the 2 wall light fittings I have installed. But as soon as I connect it all together the short returns.
If I turn the lights on they work and do not trip out the breaker. Obviously though I don't want a short.
Any ideas as to what may be causing thismamy Thanks
As above you are reading the lamps, not a dead short as such as that wouldn't permit the breaker to switch on.
Yes the lamps are in. I will take them out and do the test again and let you know. Thanks
Lamps taken out and no short. I have 4 lamps and when I put 2 in no short but when I put in the 3rd the short returns.
My main concern is that when the lights when all on and fitted the short goes through to my other pos and neg circuits on the consumer unit
It is not a short, ignore it, you are seeing the low resistive values of a pre energised lamp when energised resistance and/or inductive fields will build up preventing shorts, this is why we remove all loads from circuits before testing to ensure no false positives.
The new consumer unit in garage is wired in 6mm sea cable and has its own RCD breaker. All other circuits are fine just the lighting circuit. But as advised it looks like I was picking up the lamps as the were in when cable tested
What Buzz was getting at is the installation of a consumer unit in a dwelling is notifiable to Building Control under Part P of the Building Regulations. This is a legal requirement.
Thanks for you help. Much appreciated. Made my Saturday a lot easier. Can go enjoy the football now
Hi all,
You mean L and N POS and NEG are DC terms
Reply to Short on pos and neg in the Lighting Forum area at ElectriciansForums.net
good thinking ps electrics i'll run with that. thanks
2 3
If the main switch is on when testing global IR then the neutral and earth will likely give a very low reading. Not that anyone would...
loz2754
L
