Should an outside cable splitter be boxed? | on ElectriciansForums
Discuss Should an outside cable splitter be boxed? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
gary2016ww
Hi all,
We are the leaseholder of a ground floor council flat in a small building. As we used to be with Virgin Media, it seems an engineer from Virgin Media has cut the cable which leads solely into our house and installed a cable splitter (situated a couple of feet above the ground) just before the cable goes into our flat. Rather than run a line across the wall of the flat upstairs who are having the Virgin Media installed - 3rd storey), the engineer has run a new line across the bottom part of our living room and kitchen wall to connect with this splitter.
As I don't know much about electrics, my question is, if you're able to help, should this metal splitter be covered with a protective box to protect against weather etc. All the ends of the metal splitter are connected with cables (2 cables on one side and 1 cable on the other). Or is it safe to remain like this?
I have attached a picture.
Many thanks
Regards,
[ElectriciansForums.net] Should an outside cable splitter be boxed?
It is safe to remain like that.
The installer has avoided excess high level work by running the cable horizontally at low level (but not considerately).
The connections are F connectors that screw together and so should maintain a reasonable level of weather protection even if a sealant or gel has not been used.
The connections, if not protected, will suffer from weather exposure degradation which will affect the signal quality over time, not dangerous but inconvenient.
I would describe this as a low quality but functional installation.
The splitter would usually be described as an internal splitter.
Yes safe , but rough and requires improvement.
I doubt the clipping will last long either, that compo does not look the best.
I had VM come to install my cable tv, did exactly the same, a clip every 6 feet, splitter left hanging, when I called up the installation manager, I told him I would leave some feed for the "engineer's" horse, didn't go down to well either, still never mind, got fed up with waiting and finished the clipping and put the splitter in a suitable plastic box I had in my shed.
If you get Virgin back to make improvements, ask them to put a few more clips on the cables and hammer in the nails fully on the existing clips!
Thanks Mate not going to bother with them, my drive will only hurt their knuckles when they arrive.
Hi all,
Many thanks
Regards,
did a dog install that... ruff, Ruff.
Reply to Should an outside cable splitter be boxed? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
